Creation of hidden variable blocks
Posted: Wed Mar 14, 2018 1:40 pm
by Priscila
Good Morning,
I would like to know if it is possible to create blocks within the vensim, for example, one block of variables provides a result that is used in another block with other variables. The idea would be to hide the variables in each block.
Re: Creation of hidden variable blocks
Posted: Wed Mar 14, 2018 2:11 pm
You can hide variables (or delete from from all views), is that what you mean?
Posted: Wed Mar 14, 2018 3:35 pm
Variables inside macros are also hidden for most purposes.
However, there's no general hierarchy.
Posted: Wed Mar 14, 2018 4:03 pm
by Priscila
Below is a model for example, where I would like the number of panels and the load to be inside the solar energy variable.
When it was necessary to change these variables I would go into the solar energy block and change.
I need to do this so that the model is not visually polluted as it increases.
Posted: Wed Mar 14, 2018 4:45 pm
I think what you really need to do is use multiple views.
Open the Vensim help, click the "User Guide" section, then chapter 9 (multiple views).
http://www.vensim.com/documentation/ind ... ?usr09.htm
