GET TIME VALUE for PLE Plus
SteveVijayan
Vensim version: PLE+
Post by SteveVijayan »
Can GET TIME VALUE function be used in PLE Plus?
Re: GET TIME VALUE for PLE Plus
No, Vensim PLE cannot read from external data files (which is what GET TIME VALUE does). The help system does mention that it is not available in PLE or PLE Plus.
See
http://www.vensim.com/documentation/ind ... _value.htm
SteveVijayan
Thank you.
What do you need it for? Maybe there's another way.
SteveVijayan
I am modeling arrival and departure rates of an entity which varies by hour-of-day.
For example, 6 entities may arrive at simulation time (in hours) 7, 3 entities arrive at hour 10, 3 depart at hour 12, etc.
I need to specify these arrival and departure rates by simulation time.
You could put them in a lookup.
SteveVijayan wrote: Tue Jun 05, 2018 1:03 pm I am modeling arrival and departure rates of an entity which varies by hour-of-day.
So do you only want the simulation time?
SteveVijayan
Yes, thats correct. I am looking to create a table based on simulation time.
arrivals = arrival table(time/unit time)
unit time == 1 ~ with unit of whatever your time unit is; this suppresses warnings
arrival table ( { make this a lookup containing your data } )
SteveVijayan
Thanks Tomfid. I'll try this.
