Help with including external images in Vensim sketch
billh
Post by billh »
Can someone help me learn how to include external images in a Vensim sketch reliably?
An example:
  • I opened DSS (I'm running 7.3.4).
  • I created a new model.
  • I selected the Comment tool. The Graphics panel had "None" selected, and "Bitmap" and "Metafile" were grayed out.
  • I selected a random window on my computer and pressed Alt-PrtScrn. Then I moved the cursor to the Comment window and pressed C-v.
  • I closed the Comment window, and nothing was there.
I have made it work once--I can see the image in my existing model file--but I can't add a second such image on a new view. When it did work, I think I was able to select the Metafile radio button and press C-v, after which the radio buttons were grayed out. When I then closed the Comment window, the image appeared on the view.
I thought that at least closing and reopening DSS would re-activate the Metafile button, but it did not.
I would Import the image, but that takes a .bmp file. In my current case, I'm using a complex graph out of R. The .bmp is about 20BM, while a .png is about 250kB, and a .wmz is about 170kB.
I have looked at https://www.vensim.com/documentation/23015.htm, but that hasn't helped me yet.
Bill
Re: Help with including external images in Vensim sketch
It's not very clear how to get something from the clipboard.
1. Make sure you have your image on the clipboard.
2. Insert a new comment.
3. Click the "Bitmap" button
4. Click OK.
I'll raise this as an issue to improve things as it's not obvious at all what to do here.
billh
Post by billh »
Thanks. I suspect getting the image on the clipboard was part of the problem; I don't generally know how to see the clipboard contents on Windows without pasting them somewhere.
When raising the issue, can you consider allowing WMF files? As I noted, my bitmap in this case is about 20MB, which makes for a pretty big model file (especially when I have at least two of these images planned for this model).
daler6
Post by daler6 »
I am having the same problem. I am using the latest versions of VensimPLE and VensimPro on a Mac running Catalina. When I insert a new comment, the Bitmap and Metafile buttons are greyed out, even though there is an image on the clipboard. I have also tried to use the Import button, which did allow me to select a *.bmp file. When I selected the file, though, everything in the Graphics part of the window went grey and when I hit OK, nothing appear on the screen except for a little circle. About all I have been able to do with this circle is change its color. Also, it only appears when I select Move/Size. Very strange.
daler6 wrote: Thu Feb 06, 2020 6:24 amon a Mac running Catalina.
It may be that Apple have changed something again. I'll test with my machine here and report back (I'm running Mojave, I will not be upgrading to Catalina anytime soon).
