I have implemented new feature to my model but when I run it after completion of compiling process, I encounter with "floating point overflow-saving to time 167.000" error, but in command these errors are visible:
ERROR: line 195 of input - wrong value of parameters in the arc line.
ERROR: line 1 of input - node descriptions must be before arc descriptions.
How can I understand from which part of model this floating point overflow error is stemmed, considering two additional errors?
Best Regards,
Node description error
Re: Node description error
Is this from Vensim? I don't recognize the errors at all.
I have attached the error. My model has some external functions but its compiling process goes well and this error comes, when Vensim is simulating.Administrator wrote: ↑Wed Oct 17, 2018 2:43 pm Is this from Vensim? I don't recognize the errors at all.
- node description2.jpg (248.95 KiB) Viewed 3146 times
If you search the source code of the external functions, do you see anything like "node descriptions"?
I've never seen those before, and they mean nothing to me. And searching the Vensim source code gives no match on "node descriptions". It looks like some custom code that reads in something with arcs and nodes (whatever they are).
Yes. this error is related to my compiler(C++). As I have not still solved this error, I would like to ask you another question regadring error monitoring in Vensim. Some of my variables with Auxilary type should get amount for all time steps, but when I trace its components with table it gets value only for the first time step. Do you have any suggestion that which parts have to be checked. As you can see in the picture, those three variables(red boxes) get no value for further time steps and creat " floating point overflow" error.Administrator wrote: ↑Fri Oct 19, 2018 7:03 am If you search the source code of the external functions, do you see anything like "node descriptions"?
Best Regards,
- table.png (31.05 KiB) Viewed 3126 times
Vensim cannot report any errors with your external functions, and you need to ensure that they are well behaved. Just because they compile, that does not mean they work.
If you are missing values for aux variables, that looks like something is overwriting memory that it should not. The most likely cause in this case is the external functions, and there is nothing we can do to help you debug those.
