Good night,
I would like to know if there is any function that can do research in excel. For example, I have the wind speed entering a variable that is the power curve (which relates wind speed to output power) and needs to get output power. The power curve is in excel on a table, according to the precise input speed get the power output.
Search excel
Re: Search excel
Is the table in excel a static set of numbers? If yes, you can import them as a lookup table.
Post the spreadsheet and we can take a better look.
Re: Search excel
Good Morning,
The numbers in the table are constant; they do not vary throughout the simulation. How can I use a lookup table, which function. Attached to the worksheet.
- Planilha.xlsx
- (9.59 KiB) Downloaded 195 times
Re: Search excel
