Use File and built-in distributions for sensitivity
WayneZhou2009
Post by WayneZhou2009 »
Hi, is it possible to use both File and the built-in distribution for one sensitivity analysis?
For example, a user-defined file is used for parameters A and B, and the built-in Random Normal and Random Uniform are used for parameters C and D. Based on this setup, run sensitivity simulation. This does not seem to be doable through the Sensitivity Simulation Setup dialog.
Thanks.
Re: Use File and built-in distributions for sensitivity
No - the two approaches can't be combined. You could generate normal or uniform samples in the file using Excel functions though.
