Crashes frequently on Windows 10
Posted: Mon Apr 01, 2019 4:53 pm
by bgresh
Crashes frequently on Windows 10 while editing converters, especially after copy paste
Re: Crashes frequently on Windows 10
Posted: Mon Apr 01, 2019 5:43 pm
What do you mean by a converter?
And can you upload a model with instructions on how to re-create the crash? We might have a workaround (or be able to fix the bug quickly).
Posted: Mon Apr 01, 2019 6:15 pm
Converter = Auxiliary
Posted: Tue Apr 02, 2019 6:05 pm
by Phill
Just in case it's linked, I'll add my question to this thread. When I try to copy a section of a model and paste it into another view, even though I've been careful to set a prefix for any duplicated variables, I occasionally get a 'Vensim program error', saying 'Repeated in Onesort' and the program locks. I have to use the task manager to close Vensim.
- Vensim error.JPG (16 KiB) Viewed 19422 times
Posted: Tue Apr 02, 2019 6:12 pm
If you can give us a model that demonstrates this, I'd be happy to take a look.
Posted: Tue Apr 02, 2019 6:54 pm
by Phill
Thank you, but it seems to be the program, not a particular model, that is the problem here. This happens with any model if I copy a section of code, then try to paste it into another view with the paste settings shown in this image (the prefix 'Prem' is just an example, it happens with any prefix).
- Vensim error. 2JPG.JPG (36.8 KiB) Viewed 19418 times
Posted: Tue Apr 02, 2019 7:03 pm
by bgresh
yes, that is what I am experiencing as well
Posted: Tue Apr 02, 2019 7:48 pm
I'll run this through the debugger tomorrow and see if I can fix it quickly.
Posted: Tue Apr 02, 2019 11:17 pm
Strange. I can paste with a prefix all day long, no issues.
Posted: Wed Apr 03, 2019 12:36 am
by bgresh
I get the crashes after I paste, and when I am editing the variable names.
Posted: Wed Apr 03, 2019 8:32 am
I'm not getting any crashes either.
Can you let us know the exact steps you take (I'm selecting some model structure using the mouse, CTRL->c to copy, and CTRL->v to paste, then editing variable names using the standard AUX tool). It may be that the steps you take exercise different parts of the code which causes the crash.
Posted: Wed Apr 03, 2019 10:11 am
by bgresh
I have been trying to replicate but have not yet found the exact sequence.
Posted: Fri Aug 14, 2020 7:18 pm
by jah@umamexico.com.mx
Hello!
I have the same problem with Vensim error "Repeated in onesort".
I would like to ask for support on how to solve it, considering I can not open the model.
Thanks in advance.
Regards
Posted: Fri Aug 14, 2020 8:10 pm
Can you upload the model so we can take a look?
Posted: Wed Aug 19, 2020 11:48 pm
Sure!
Thanks in advance!
Posted: Thu Aug 20, 2020 2:40 pm
I can replicate the problem. We should have a solution soon.
Posted: Thu Aug 20, 2020 3:39 pm
You have two equations for "Contaminación" in the model file. You will need to edit the model with a text editor and delete the one that is incorrect.
Posted: Thu Aug 20, 2020 4:03 pm
Deleting one instance doesn't solve the problem for me. I think there may be multiple problems, or something deeper.
Posted: Thu Aug 20, 2020 11:03 pm
The problem is that both
CONTAMINACIÓN
and
Contaminación
exist in the model. I'm not sure how this could happen, except perhaps in an old pre-unicode version of Vensim.
The attached deletes the offending duplicates.
Posted: Wed Sep 09, 2020 9:30 pm
by Travis
We've also had crashes in Windows 10. This thread looks like a specific issue, and we can't narrow our situation down. Often it happens when in SyntheSim mode in and trying to hunt down behavior in a large model.
