Read in time-dependent array from Excel
Sandra
Post by Sandra »
Hi!
I have an Excel sheet containing export streams from one region to another on different time dates (// indicate new column, --- indicate new row).
From// To // 2018// 2019// 2020---
USA// Germany// 0// 10// 20---
USA// China// 10// 20// 30---
USA// USA// 0// 0// 0//
Germany// USA// 5// 10// 20---
Germany// China// 5// 5// 5---
Germany// Germany// 0// 0// 0---
China// USA// 10// 15// 20---
China// Germany// 10// 5// 0---
China// China// 0// 0// 0---
My wish would be that I create a variable in Vensim, that is able to display this array as well. I defined two subscripts:
Subscript 1 (ExportCountries): USA, Germany, China
Subscript 2 (ImportCountries): USA, Germany, China
But I always failed that the variable ExportStream[ExportCountries,ImportCountries] is able to display this time-dependent array in Vensim as well.
Can you please help me how to read in multiple arrays from Excel into Vensim?
Thanks in advance,
Sandra
Problem.xlsx
(8.97 KiB) Downloaded 144 times
Re: Read in time-dependent array from Excel
If you're using GET XLS, it can only handle one dimension (plus time) at a time. So, you'd need three equations to import this:
data[USA,importCountries] = GET XLS DATA( ... , 'C5' )
data[Germany,importCountries] = GET XLS DATA( ... , 'C8' )
data[China,importCountries] = GET XLS DATA( ... , 'C11' )
(Also check the sample model in the Help system, linked to the GET XLS DATA topic.)
For this kind of thing, it may be easier to import the data to a .vdf - you just need to get your input data into an appropriate format - for example:
Problem2.xlsx
(8.48 KiB) Downloaded 161 times
