Hello Everyone,
I’m trying to carry out Extreme Condition Test but it gives an error message “Floating point error computing - Order Fulfillment Ratio - at time = 0.000000”. Trying to save the results anyway.
I would really appreciate some help in sorting out this issue.
Help in Extreme condition testing
- Experiment1A.mdl
- (6.95 KiB) Downloaded 784 times
Re: Help in Extreme condition testing
It's a simple division by zero. "Desired shipment Rate" is zero which causes the problem.
The quickest way to correct this is to use the ZIDZ function.
Thanks for your reply it helped a long way.
