When working with colleagues who use Windows and macOS, there is always a dialog (mainly on macOS) that says the model was saved on a different platform and needs to be scaled.
This is a predictable situation:sharing models between Vensim Win and Vensim macOS. Please solve this situation for the user -- don't make it so every time a model is shared there is a two or three step process, with modal dialog boxes, before you can see and run the model.
Please either 1) come up with a standard conversion for each direction and/or 2) introduce display independent views and coordinates in v8 so Vensim can always draw views correctly.
MacOS issue: Please solve the drawing resolution issue
- Screen Shot 2019-07-10 at 1.49.36 PM.png (174.79 KiB) Viewed 3845 times
