Vensim 8 vdfx extension compatibility
Hello, I'm developing a model in collaboration with a friend. After I update to Vensim 8 it started to creat vdfx files instead vdf. My collaborator is still using the old version and couldn't open my vdfx files. What solution do you have for this issue?
Re: Vensim 8 vdfx extension compatibility
The only thing you can do is export the dataset and send that instead. They can then import it.
Or a better solution would be to send the model and files needed to run it and ask them to run the model themselves.
