I want to set "fluctuated price1" to be "1" as long as "randomized prices" are not zero in three-consecutive time.
(otherwise set "fluctuated price1" to be "0" )
What shall I do?
I attach the model.
three consecutive values
- example_vensim.mdl
- (1.18 KiB) Downloaded 164 times
Re: three consecutive values
I don't understand what you want to do.
Do you want to take a random sample and make it last for a certain amount of time?
If you want to test for price = 0, that event is incredibly unlikely, even if the mean of the distribution is 0, and three in a row will probably never happen, even if you run the model for years. Your Normal distribution is truncated at 1, and in any case 0 is 14 standard deviations below the mean, so it will definitely never happen.
However, if you change the distribution and the test so that there's some likelihood of price<=0, you could count those instances with a stock:
Great!.
Thanks Tom.
Cheers,
Bahri
Thanks Tom.
Cheers,
Bahri
