Sensitivity Graph Y-Axis Range
Quick question: Is there a way of manually setting the upper limit of a sensitivity graph? I'm aware that you can right-click and drag on the graph to choose an arbitrary range, but this visual method is never precise.
Many thanks,
Kaveh.
Many thanks,
Kaveh.
Re: Sensitivity Graph Y-Axis Range
No, there is no way of setting it.
Sorry, if I can just follow up on that, I think I might need to export results to Excel to be able to customize my chart.
Is there a way to export or obtain only the few confidence bound curves, rather than all the hundreds of runs?
Thanks again.
Thanks again.
Unfortunately not. But I'll add it to the list of improvements for Vensim.
Thanks. I managed to get a decent sensitivity graph with custom axis ranges via editing a .vgd file in text.
Also, you actually can export sensitivity data with confidence bounds, using a cmd script and SENS2FILE with the % key - https://www.vensim.com/documentation/sens2file.htm
Thanks Tom. Sorry for the obvious question but in which environment would I run this command? Would it be Terminal on a Mac or the Command Prompt in Windows?
Neither - this would be a cmd script within Vensim, which requires DSS.
Thank you Tom! That's helpful.
