Hello there!
I have this one question regarding on the model that i'm currently working with.
I have 2 variables; sorted marginal cost and sorted generation as show in figure below.
These two variables are mapped under the same subscript and both are actually correlate. But my problem is, how do i arrange these two variables that can give me an output like this;
Is it possible to do so?
How to map one variable to another variable?
Re: How to map one variable to another variable?
Can you upload the model? I'm sure it's possible, but we don't have enough information to help.
Maybe vector elm map function is what you need?
You can use vector elm map to pick elements out from another subscripted parameter.
Here it isAdministrator wrote: ↑Fri Oct 09, 2020 3:56 pm Can you upload the model? I'm sure it's possible, but we don't have enough information to help.
It's on the MARGINAL COST's view.
- Initial One.mdl
- (55.21 KiB) Downloaded 202 times
I tried using VECTOR ELM MAP as suggested, but it seems it didn't work (or maybe i used it wrong?)Administrator wrote: ↑Fri Oct 09, 2020 3:57 pm Maybe vector elm map function is what you need?
Anyone can please help me? :'(
I'm not sure I understand what you need to do. Are you asking how to generate an Excel sheet with the parameters as you have them in your sheet?
If the requirement is a table that interleaves marginal cost and generation, as in your example, I don't think there's a way to do that within Vensim.
