Truncated lognormal
lorenzo.cioni
Truncated lognormal
Post by lorenzo.cioni »
Hi everybody
is there any way to use, in a Vensim model, a variable that simulates a truncated lognormal? I know how I can simulate a "full" lognormal through a normal distribution but what about the insertion of a maximum positive value? How can I rescale so that the area under the truncated disribution is still equal to 1?
All the best, thanks in advance for any suggestion. 8)
Lorenzo
Re: Truncated lognormal
The RANDOM NORMAL function generates a truncated Normal distribution, so if you transform that you'll get a truncated Lognormal. You could do something like:
randx = EXP( RANDOM NORMAL(-something large, LN(max val), LN(geometric mean), geometric SD, stream ID) )
lorenzo.cioni
tomfid wrote: Sat Oct 17, 2020 2:03 pm The RANDOM NORMAL function generates a truncated Normal distribution, so if you transform that you'll get a truncated Lognormal. You could do something like:
Hi tomfid
thank you a lot... fast and precise as usual :D :D
All the best.
Lorenzo 8)
lorenzo.cioni
Hi tomfid
is it the same if I use this form?
randx = EXP( normal_mean+normal_std_dev*RANDOM NORMAL(-100, LN(max val),0, 1, 0 )
Lorenzo
Yes, as long as LN(max val) represents the maximum departure in terms of number of geometric std dev above the mean.
lorenzo.cioni
Hi tomfid
could you be more clear about this: "the maximum departure in terms of number of geometric std dev above the mean"?
Indeed I have to generate a lognormal whose normal parameters are μ = −13.3 and σ = 3.49 truncated on the interval [0, 2.35 × 10−3]).
Lorenzo
That would be:
EXP( RANDOM NORMAL(-100,-6.05,-13.3,3.49,stream) )
where -6.05 = ln(2.35e-3)
The -100 is just a big number (30 standard deviations roughly) - the truncation at 0 isn't really needed since the lognormal is always >0.
lorenzo.cioni
tomfid wrote: Sat Oct 17, 2020 3:18 pm That would be:
Hi tomfid
thank you a lot. :D :D
All the best.
Lorenzo 8)
