The Vensim help https://www.vensim.com/documentation/re ... _vals.html describes the \/ method for displaying a string variable for a variable label in a custom plot. The example shows how this method works for two elements. Can the method also work when the name of the range is passed instead of the elements?
In custom plots, I have found it useful to list the range along with the variable name: the custom plot shows the elements that have been selected with Subscript Control. But this trick doesn't seem to work with the labels. Instead the label shows only the first element of the range.
An example is attached. Any clues?
Best regards,
Rob
Custom plot string labels
- string_label.mdl
- (1.43 KiB) Downloaded 590 times
