I have used a cmd file in a Matlab code by this command:
SPECIAL>LOADMODEL|tempin.mdl
MENU>RUN|O
MENU>VDF2DAT|1.vdf|2.dat|s.lst
the result file (2.dat) is not accessible inside the code until the code has ended completely. In other hand, it is generated properly but is not accessible for use in next line of code. appreciate for your help.
command script delay
Re: command script delay
You need Vensim DSS to link with Matlab.
thank you but i have this problem with DSS version 6.4
it seems the output file (2.dat) remain in PC memory and is released just at the end of code, so the following code lines which comes after vdf2dat line and use 2.dat file are not executed.
Please update your profile with your correct licence details and we will be happy to help. You registered as a PLE user.
Thank you for your kindness. I finally managed to solve the problem
