I'm having the following problem
kong17
Post by kong17 »
Hello everyone,
In one part of my model, I need to use the Find Zero Function. Because too many variables are calculated, I use subscripts to simplify the model, but an error occurs during runtime (Floating point overflow - saving to time 0.00000). The attachment is a simple example. I was wondering how to solve it?
Thank you for your help!
FIND ZERO.mdl
(5.77 KiB) Downloaded 836 times
Re: I'm having the following problem
That model runs fine for me. Have you uploaded the correct model?
I don't get an error. What version are you using?
kong17
Post by kong17 »
Thank you for your reply.
My version is DSS.
It stills get an error.
Can you try it in double precision version of Vensim?
kong17
Post by kong17 »
Administrator wrote: Thu Jul 29, 2021 2:06 pm Can you try it in double precision version of Vensim?
Hi, Thank you for your reply.
I was wondering what is the double-precision version? Do I need to redownload?
kong17
Post by kong17 »
tomfid wrote: Thu Jul 29, 2021 12:14 pm I don't get an error. What version are you using?
My version is DSS.
kong17
Post by kong17 »
Hi, I download the double precision.
It doesn't get an error anymore.
But, I was wondering why some results are only shown one subscript?
FIND ZERO.mdl
(5.83 KiB) Downloaded 1092 times
kong17
Post by kong17 »
Hi, I try to open my model in double precision that I download the new version. But, it said 'Syntax Error'.
I can open it in the prevision version (Vensim 7.3.5 single precision).
I was wondering what's wrong with it?
Thank you for your help.
You have "size n" = 1. It should be set to the ELMCOUNT(commod) normally.
If you're getting a syntax error in double precision, after successfully opening it earlier, the file is probably corrupted somehow. The version you posted here works fine for me, especially after the ELMCOUNT change.
kong17
Post by kong17 »
tomfid wrote: Thu Jul 29, 2021 5:13 pm If you're getting a syntax error in double precision, after successfully opening it earlier, the file is probably corrupted somehow. The version you posted here works fine for me, especially after the ELMCOUNT change.
Thanks, it works very well.
By the way, If I try to solve the syntax error, which means I have to rebuild the model in double precision if I want to run it.
Is it correct?
There shouldn't be any difference between single and double precision with respect to syntax. Not knowing what the specific error is, it's hard to say more.
kong17
Post by kong17 »
tomfid wrote: Thu Jul 29, 2021 6:04 pm There shouldn't be any difference between single and double precision with respect to syntax. Not knowing what the specific error is, it's hard to say more.
Ok, I see.
kong17
Post by kong17 »
I might find why I couldn't open my model in the double precision. I copy the ALLOCATE BY PRIORITY function in my single precision to double precision. It gets errors '' Missing a closing parenthesis on a lookup table call'', but it works in the single precision.
And, when I try to use the ALLOCATE BY PRIORITY in the Functions list (double precision), the software crashed and directly quit.
I even tried to create a new model, but as long as I clicked on the ALLOCATE BU PRIORITY from the functions list, the software must be crashed.
I don't know why. Many thanks for your help.
Can you upload the model?
Is one of the parameters (max capacity..., effect of gener..... or capacty for CM a lookup table?
kong17
Post by kong17 »
Administrator wrote: Tue Aug 03, 2021 7:45 pm Can you upload the model?
Thank you for your reply. I only uploaded the part that was reported the error in my model.
I have tested it, the same structure, it works in the single precision.
I also download the example about ALLOCATION BY PRIORITY in the VENSIM HELP.
When I want to change to Sketch, it also reported a Syntax error.
Is it because my license has expired, and some functions of the downloaded double precision version are missing?
Looking forward to your reply, thank you.
simple model.mdl
(2.27 KiB) Downloaded 1059 times
No, it's not because your licence has expired.
That model opens fine for me. What is the exact version of Vensim you are using and I'll try that.
kong17
Post by kong17 »
Administrator wrote: Tue Aug 03, 2021 8:45 pm No, it's not because your licence has expired.
The following figure shows the version that I used.
The model you uploaded loads fine for me in 8.1.0 as well.
If the big model is sensitive, you can send it to vensim@vensim.com and I can take a look. It may be that the error is pointing to a different parameter.
kong17
Post by kong17 »
Administrator wrote: Tue Aug 03, 2021 9:01 pm The model you uploaded loads fine for me in 8.1.0 as well.
Thank you. I will send it later. But I think the model is fine. The error seems to have nothing to do with the model.
I build a new model (only one Variable). When I want to click ALLOCATE BY PRIORITY in the Equations from Functions. The software is directly closed. The ALLOCA P and ALLOCATE AVAILABLE can be clicked.
I also test it on my laptop, same problem.
I try to download the software again. Does the existence of single precision (7.3.5) and double precision (8.1.0) in the computer have any effect?
