entity actions from data
seeker
Post by seeker »
What's the best way to calibrate with entities and time-series data in Ventity while still maintaining collections? For example, how can I use time series data in which a particular cow moves to a new pasture or dies and leaves the farm and new cows are imported?
Re: entity actions from data
Good question. I think it depends what the data looks like - do you have an example?
seeker
Post by seeker »
Thanks for the reply. Here is an example of data. We start out with 10 cattle in the first month. In the second month, a few cattle have moved pastures e.x. c001 is now in p002 and some are dead (c008 and c010), and we bought a new cow c011 to pasture p004 and pasture p003 is now empty. Let's assume the simulation plots are the number of cattle of each gender in each pasture. How do I add this time series data as a sample realization/simulation run?
Date CattleID Pasture Gender Alive
1/1/2021 C001 P002 F 1
1/1/2021 C002 P004 M 1
1/1/2021 C003 P002 M 1
1/1/2021 C004 P001 F 1
1/1/2021 C005 P003 M 1
1/1/2021 C006 P004 F 1
1/1/2021 C007 P001 F 1
1/1/2021 C008 P003 F 1
1/1/2021 C009 P001 M 1
1/1/2021 C010 P002 M 1
2/1/2021 C001 P001 F 1
2/1/2021 C002 P004 M 1
2/1/2021 C003 P001 M 1
2/1/2021 C004 P001 F 1
2/1/2021 C005 P002 M 1
2/1/2021 C006 P004 F 1
2/1/2021 C007 P001 F 1
2/1/2021 C011 P004 F 1
2/1/2021 C009 P001 M 1
seeker
Post by seeker »
Any ideas? I'm new to ventity but know how to do this in OO languages using functions.
It looks like the data essentially matches the Tidy template, if you change "Date" to "DateTime". See Defining Entities>Data Entities>Data Sources in the Help system.
Given the data, are you looking to compare it to what the model is generating, or to use the cow location data as a driver for what happens in the pastures (for example)?
seeker
Post by seeker »
Thanks, good question. I am looking to use it as a driver for now. I anticipate I will also use it to compare what the model is generating in other models.
seeker
Post by seeker »
Thank you so much @tomfid! Data Entities is what I needed.
I'm working on an example for you but ran into a bug so I'm not sure how long it'll take.
seeker
Post by seeker »
That's fantastic. I appreciate it-it will be very helpful.
seeker
Post by seeker »
I am getting the following exception when I try to use CalendarTime from the excel file. Is there a specific calendar format I need to be using while importing data from excel?
Level 0 Exception
TYPE : OverflowException
MESSAGE : Array dimensions exceeded supported range.
SOURCE : VentityGlobals
METHOD : GetActiveTimeControl
STACK TRACE : at VentityGlobals.RuntimeContext.GetActiveTimeControl(IModelRunConfig runConfig)
at VE_RuntimeManager.ModelInput.ModelTimeSeriesData.CalculateInterpolatedValues(IModelTimeSeriesData timeSeriesData, RuntimeContext runtimeContext, IModelRunConfig modelRunConfig)
at VE_RuntimeManager.ModelInput.ModelTimeSeriesData.FromScenarioTimeSeriesDataSource(RuntimeContext runtimeContext, IScenariosDataSource scenariosDataSource, IRuntimeAdapter runtimeAdapter, IModelRunConfig modelRunConfig)
at VE_RuntimeManager.ModelInput.ModelTimeSeriesDataManager.GetModelTimeSeriesData(RuntimeContext runtimeContext, String uid, IRuntimeAdapter runtimeAdapter, IModelRunConfig modelRunConfig)
at VE_RuntimeManager.FastDataManager.LoadTimeSeriesData(RuntimeContext runtimeContext, IRuntimeAdapter adapter, IModelRunConfig modelRunConfig)
at VE_RuntimeManager.RuntimeManager.CreateRunTask(RuntimeContext runtimeContext, IRuntimeAdapter adapter, IModelRunConfig modelRunConfig, Boolean baseRun)
at VE_RuntimeManager.RuntimeManager.<CreateRunTasks>d__14.MoveNext()
at VE_RuntimeManager.RuntimeManager.<Run>d__11.MoveNext()
at VentityMainForm.AppMainForm.<>c__DisplayClass394_0.<RunModel>b__2()
*** this is probably indicative of the original error ***
Can you share the project files?
seeker
Post by seeker »
Attached is a dummy example creating a data entity from the excel file with dates and selecting calendar time in run control.
