Built-in Data
Milos
Built-in Data
Post by Milos »
I am having a few problems:
1. I have a build in data set, Variables that were created and checked as constants before the data set was generated, they appear in the data set. All new variables that are build after the data set was generated, are not visible in the builin data table. If I generate a new built in data they will be in present in that table.
2. The copy paste of multiple cells and columns from built in data table to a new built in data is not working, also if I want to copy paste from a excel multiple cells to a built in data table it will paste in a wrong row and column and the sequence is constantly wrong.
Kind regards,
MJ
Re: Built-in Data
1. There's a checkbox at the top of the Builtin pane that controls whether all cells, or only used cells are shown. Try checking that.
2. I'll investigate this. I think it's a known issue, but I thought it was fixed.
