Vensim Crashing
Posted: Mon Jan 10, 2022 2:43 am
So I have been having this problem quite a lot, and it happens when I try to make connections in the model which are quite far apart. I draw the arrow and as soon as I make it, it crashes the program. I then get this text beneath which I am not sure if it is useful but I have included it just in case. I have a MacBook Pro running on MacOS Big Sur version 11.2.1. The version of Vensim is: Vensim PLE 9.0.1 x64. The Serial number is PL9999. Let me know if there is something I can do.
Thanks very much in advance.
The copy paste of the error (had to take some of the coding out as it was too long):
Process: VensimPLE [16140]
Path: /Applications/VensimPLE.app/Contents/MacOS/VensimPLE
Identifier: com.vensim.VensimPLE
Version: 09000100 (VensimPLE 09000100)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: VensimPLE [16140]
User ID: 501
Date/Time: 2022-01-10 02:35:17.349 +0000
OS Version: macOS 11.2.1 (20D75)
Report Version: 12
Anonymous UUID: 33A1AF87-7583-6E73-DBD8-25EF02FC4A5B
Sleep/Wake UUID: 99EF9677-CADC-43AC-9FFE-22FEAB1A86F5
Time Awake Since Boot: 480000 seconds
Time Since Wake: 110000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fbdf9af2a98
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [16140]
VM Regions Near 0x7fbdf9af2a98:
Stack 70000dea8000-70000df2a000 [ 520K] rw-/rwx SM=COW thread 3
MALLOC_TINY 7fbecb400000-7fbecb500000 [ 1024K] rw-/rwx SM=PRV
7 com.vensim.VensimPLE 0x00000001023434e0 wxEvtHandler::ProcessEvent(wxEvent&) + 96
8 com.vensim.VensimPLE 0x00000001021c7002 wxScrollHelperEvtHandler::ProcessEvent(wxEvent&) + 34
9 com.vensim.VensimPLE 0x0000000102343bfc wxEvtHandler::SafelyProcessEvent(wxEvent&) + 12
10 com.vensim.VensimPLE 0x00000001020b19c9 wxWidgetCocoaImpl::DoHandleMouseEvent(NSEvent*) + 89
11 com.vensim.VensimPLE 0x00000001020954c6 -[NSWindow(wxNSWindowSupport) WX_filterSendEvent:] + 150
12 com.vensim.VensimPLE 0x0000000102095510 -[wxNSWindow sendEvent:] + 32
13 com.apple.AppKit 0x00007fff22f6d384 -[NSApplication(NSEvent) sendEvent:] + 352
14 com.vensim.VensimPLE 0x00000001020037e2 -[wxNSApplication sendEvent:] + 98
15 com.apple.AppKit 0x00007fff23245f1e -[NSApplication _handleEvent:] + 65
16 com.apple.AppKit 0x00007fff22dd66af -[NSApplication run] + 623
17 com.vensim.VensimPLE 0x000000010208b77a wxGUIEventLoop::OSXDoRun() + 186
18 com.vensim.VensimPLE 0x0000000102321b2d wxCFEventLoop::DoRun() + 29
19 com.vensim.VensimPLE 0x000000010227253e wxEventLoopBase::Run() + 158
20 com.vensim.VensimPLE 0x00000001022440e3 wxAppConsoleBase::MainLoop() + 99
21 com.vensim.VensimPLE 0x000000010204764a wxApp::OnRun() + 26
22 com.vensim.VensimPLE 0x00000001022ac158 wxEntry(int&, wchar_t**) + 56
23 com.vensim.VensimPLE 0x000000010171bd23 main + 35
24 libdyld.dylib 0x00007fff204ea621 start + 1
Thread 1:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff2049ae7e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff2049b1f0 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff205c7bf7 __CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff205c62ca __CFRunLoopRun + 1315
4 com.apple.CoreFoundation 0x00007fff205c56ce CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22f6b7c6 _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff204cf950 _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff204cb47b thread_start + 15
Thread 2:
0 libsystem_kernel.dylib 0x00007fff2049d8e2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff204cfe6f _pthread_cond_wait + 1254
2 com.vensim.VensimPLE 0x000000010159c29e vensim_event_wait + 302
3 com.vensim.VensimPLE 0x0000000101596705 execute_in_new_thread_worker_function + 277
4 libsystem_pthread.dylib 0x00007fff204cf950 _pthread_start + 224
5 libsystem_pthread.dylib 0x00007fff204cb47b thread_start + 15
Thread 3:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff204a31fe __select + 10
1 com.apple.CoreFoundation 0x00007fff205ee6c3 __CFSocketManager + 644
2 libsystem_pthread.dylib 0x00007fff204cf950 _pthread_start + 224
3 libsystem_pthread.dylib 0x00007fff204cb47b thread_start + 15
Thread 4:
0 libsystem_pthread.dylib 0x00007fff204cb458 start_wqthread + 0
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007fbecd324000 rbx: 0x00007ffeee7f7668 rcx: 0x00007fbecb7ac298 rdx: 0xffffffffcb8d1a00
rdi: 0x00007fbecb793f84 rsi: 0x00000000cb8d1a00 rbp: 0x00007ffeee7f4ca0 rsp: 0x00007ffeee7f4ca0
r8: 0x00000000000003ff r9: 0x00000000000007fb r10: 0x0000000000000240 r11: 0x0000000000000010
r12: 0x0000600000f5de40 r13: 0x000000000000000d r14: 0x00007fbecd0b6800 r15: 0x0000600000f5cb60
rip: 0x0000000101a349d1 rfl: 0x0000000000010202 cr2: 0x00007fbdf9af2a98
Logical CPU: 0
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 17
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 349896
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=911.7M resident=0K(0%) swapped_out_or_unallocated=911.7M(100%)
Writable regions: Total=723.3M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=723.3M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 1152K 9
Activity Tracing 256K 1
CG backing stores 2880K 6
CG image 3176K 173
CG raster data 288K 36
CoreAnimation 78.8M 107
CoreGraphics 12K 2
CoreImage 32K 8
CoreUI image data 3968K 32
Foundation 36K 2
Kernel Alloc Once 8K 1
MALLOC 337.3M 63
MALLOC guard page 32K 8
MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)
STACK GUARD 56.0M 9
Stack 43.6M 9
VM_ALLOCATE 1072K 50
__CTF 759 1
__DATA 20.0M 471
__DATA_CONST 27.8M 303
__DATA_DIRTY 1729K 207
__FONT_DATA 4K 1
__LINKEDIT 497.0M 7
__OBJC_RO 60.6M 1
__OBJC_RW 2449K 2
__TEXT 414.8M 474
__UNICODE 588K 1
mapped file 329.9M 46
shared memory 40K 4
TOTAL 2.1G 2035
TOTAL, minus reserved VM space 1.8G 2035
Model: MacBookPro12,1, BootROM 426.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2.7 GHz, 8 GB, SMC 2.28f7
Graphics: kHW_IntelIris6100Item, Intel Iris Graphics 6100, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1675.1)
Bluetooth: Version 8.0.3d9, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
User ID: 501
Report Version: 12
Thread 2:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Logical CPU: 0
Trap Number: 14
task_for_pid: 17
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
VIRTUAL REGION
CG image 3176K 173
CoreGraphics 12K 2
CoreImage 32K 8
Foundation 36K 2
MALLOC 337.3M 63
STACK GUARD 56.0M 9
Stack 43.6M 9
__CTF 759 1
__DATA 20.0M 471
__FONT_DATA 4K 1
__LINKEDIT 497.0M 7
__OBJC_RO 60.6M 1
__OBJC_RW 2449K 2
__TEXT 414.8M 474
__UNICODE 588K 1
shared memory 40K 4
TOTAL 2.1G 2035
