I would like to assess which parameters in my model affect the model KPI's the most. This could be done with the optimization tool using payoff_sensitivity over all constants. However, I am uncertain if this analysis is valid because it calculates the optimization first?
Furthermore, is the sensitivity analysis with ALL_CONSTANTS univariate or multivariate?
Thanks in advance!
Best, Bart
Payoff sensitivity
Re: Payoff sensitivity
Correct, this is the right way to do it.
Univariate. Turn the optimizer off when doing this.
Thank you.
And is it possible to assess the impact of lookups / Excel imported data-parameters as well?
Do you want to know the impact of individual points on a lookup? If yes, you would have to construct the lookup using VECTOR LOOKUP.
https://www.vensim.com/documentation/fn ... ookup.html
If you only want to see the impact of the lookup as a whole, you can add a multiplier to the looked up value, and modify that by +/- 10%. The same would need to be done for data.
If you want the multivariate picture, you can use a sensitivity run or MCMC to randomly sample the parameter space, and then export the data and use a visualization tool to explore correlations between inputs and outputs or the payoff.
