Wondering if anybody in the community when exporting results from VDFX uses both a LST file and also the option "Export units"?
On both small and big models we are noticing that if you DON'T use LST and just export all variables from the model and if "Export units" is selected then indeed the units do get exported in an additional column.
The moment you use an LST file, the units don't get exported.
Thanks, Pawel
