Loading Data as a Model not available in Open Model menu
Posted: Mon Feb 21, 2022 11:05 am
by EwoutH
I tried to follow the
Loading Data as a Model documentation to open data without having an existing model. When I go to File > Open Model, there isn't a
Datasets (Runs) option for file types or anything else with which I can open my .vdfx dataset.
Vensim 9.1.1, Windows x64.
Screenshot and .vdfx dataset attached below.
- Screenshot_710.png (840.29 KiB) Viewed 3618 times
Re: Loading Data as a Model not available in Open Model menu
Posted: Mon Feb 21, 2022 11:15 am
We haven't implemented this yet in version 9.
You can still see the contents of the VDFX file if you export the dataset, or go back to the old GUI to do this.
Posted: Mon Feb 21, 2022 3:47 pm
Actually this does work in v9, it's just that the file type filter is missing from the dropdown menu.
You can use a standard OS trick to access it: just type *.vdf in the File Name field, and hit return - you'll see datasets listed (if there are any). Then you can select & open one.
