Tools > Options > Sketch > Font
rob_n
Post by rob_n »
I'm running Vensim 9.2 Mac. In the new Sketch, going to Tools > Options > Sketch to change the default font. I can pick a new font, but there is no way to save it! Only option is "Close". Going back to Tools > Options > Sketch confirms that the change did not stick.
It is sufficient to switch to Old Sketch, change the font, then switch to New Sketch.
FYI, looks like Vensim 9.2 PC has the same problem.
Best regards,
Rob
Re: Tools > Options > Sketch > Font
The lack of OK/Cancel options is deliberate (I think you can thank iOS for the modeless exit style).
Failure to actually save the font is a bug - we'll fix.
rob_n
Post by rob_n »
Thanks, Tom!
Will be fixed in the next release. Sadly the "Fonts" settings pane is overwriting the sketch font.
