I am having a problem with the new Export Sketch to SVG functionality in Vensim version 9.2 and would appreciate your help.
1. I opened the attached .MDL file in Vensim PLE Version 9.2.1 x64 Build TK-220303.00128
- The software was downloaded on a trial basis
- The .MDL file was created by a senior research associate at the National Institute for Health Research Applied Research Collaboration West based at University Hospitals Bristol NHS Foundation Trust using a fully licensed version of the software.
- The work was carried out for a Ripple Effects Mapping project at Active Gloucester and I have their permission to share the model with you.
3. When I opened the attached SVG file in Inkscape, I could not see anything (the same happened when opening the SVG file in Chrome). To make the SVG visible, I had to select an object and zoom into it (at 25,381% for an arrowhead!) and then bring the zoom back to 200%. This allowed me to see the image shown below. As you can see the SVG file has created a narrow line-wrapped version of the text for each element in the Vensim model, has used a relatively large font, and, as highlighted by the use of different colours on one of the elements below, has put each wrapped line into a separate text box. The separation of each line into a separate text box makes it very difficult/time-consuming to work with the data in SVG.
Could you let me know if there is a way around this problem?
Thank you
Kind regards
Paul
