The model below has a variable with two step inputs a and b, with b starting later than a, and another variable with their smoothing equivalents.
Based on the fraction b/a of the step inputs when b starts, I am trying to make the starting point of smoothing b to be relative to the value of smoothing a at this point in time.
For example, in the attached figures, since step b is equal to step a, smoothing b should not start from point 0, but it should start from the same value of smoothing a at this point in time, as shown by the arrow.
Similarly, if step b would be half the value of step a, smoothing b should start from smoothing a/2 at this point in time.
Any ideas?
Thank you!
