Hi all,
I've set minimum boundaries on several conditions, yet when they are realised, there is no warning given. I have checked "Preferences" and validated that warnings are not suppressed. Image shown as an example where the minimum was zero, and the actual was -1. No warning window is was observed during "SyntheSim". Is this expected behaviour?
Thanks,
Maxx
Simulation warnings not showing
- Screen Shot 2022-05-04 at 8.23.44 pm.png (190.88 KiB) Viewed 1140 times
Re: Simulation warnings not showing
Note: this is an issue because the model outputs non-sensical results without warning. This makes it more difficult to debug.
Can you upload the model and your Vensim settings file so we can test?
I think what you may be seeing is a consequence of suppression of some warnings during synthesim. If you do a regular run with the same parameters, do you get the warning?
Yes, that looks to be the issue. The warnings appear with a regular run of the model. Is there a way to adjust the suppression settings such that the warnings appear during SyntheSim?
- Screen Shot 2022-05-08 at 4.35.19 pm.png (44.23 KiB) Viewed 1056 times
Not during SyntheSim, there would be too many warnings for most simulations. I'll see if I can do something though.
Agree that individual warnings would be overkill. A small pop-up that makes a user aware that warnings exist might be a decent compromise.
Thanks for considering!
