Installation Error Code 977
- Vensim version: PLE
Hi! I would like to using Vensim PLE, but I can't install successfully after downloading the Installation package. The error statement is the following:
“Resource file comes from a different version of Vensim(002)”
"Reinstall Vensim(error 977)"
My Installation info:
System: Window 11 x64
System Language: Chinese
Installation path: default
Usage: Academic use, very first time installation
Appreciate your support!
Re: Installation Error Code 977
Did you install using administrative permissions?
Yes,I did.
In C:\Users\Public\Vensim\PLE, there should be a file named en09020400.vrf, can you zip this and upload it to the forum please?
The attached should work for you.
I'll need to get hold of a computer with Chinese as the operating system to test why this is happening.
- en09020400.zip
- (192.61 KiB) Downloaded 166 times
Hi, I have exactly the same situation, could you please help me out?
I attached the document in users/public/vensim, en09030200, don't know if that is what you need. But I am in a urgent of getting my assignment start. I hope this can be solved in a way. Thanks very much
- en09030200.zip
- (209.04 KiB) Downloaded 113 times
Hi, I have exactly the same situation, could you please help me out?Administrator wrote: ↑Thu May 19, 2022 12:54 pm The attached should work for you.
- en09030200.zip
- (209.04 KiB) Downloaded 93 times
Can you try the attached file?
- en09030200.zip
- (194.61 KiB) Downloaded 125 times
Awesome!!!! Thanks very much!!
I had same problem with Vensim Model Reader, I used the file from the current post but it didn't work
Can you let me know what language your computer is in please? I've set up a Chinese (simplified) machine here and Vensim installed without any problems.
My problem has been solved, thank you for your reply
Hi! I met the same situation as well,but I attached the document in users/public/vensim/PLE,just has en09030300.vrf,could you please help me check this file? Cause I am urgent to get my assignment start.I hope it can be solved as early as possible.Thank you very much!Administrator wrote: ↑Thu May 19, 2022 12:54 pm The attached should work for you.
Please start a new thread and provide some more information (such as operating system etc).
Hi! I met the same situation as well,but I attached the document in users/public/vensim/PLE,just has en09030400.vrf,could you please help me check this file? Cause I am urgent to get my assignment start.I hope it can be solved as early as possible.Thank you very much!
Hi! I met the same situation as well,but I attached the document in users/public/vensim/PLE,just has en09030400.vrf,could you please help me check this file? Cause I am urgent to get my assignment start.I hope it can be solved as early as possible.Thank you very much!Administrator wrote: ↑Tue Sep 27, 2022 5:31 pm Please start a new thread and provide some more information (such as operating system etc).
If you are running Windows, make sure you install Vensim as an administrator. Right click on the Vensim installer and select "Run as administrator".
If you still have trouble, please start a new thread and provide some information so we can help you.
Administrator wrote: ↑Wed Sep 28, 2022 7:42 am If you are running Windows, make sure you install Vensim as an administrator. Right click on the Vensim installer and select "Run as administrator".
I'm sure that I install Vensim as an administrator.
In C:\Users\Public\Vensim\PLE, there should be a file named en09030400.vrf, can you zip this and upload it to the forum please?
