Hello all,
I have a small request to which I have unfortunately not yet found a solution.
There are cases in which dividing or multiplying by the TIME STEP is helpful in assigning a time unit to a variable and thereby avoiding unit errors.
Example: I want to determine total cost of all annual public transport subscriptions. The annual subscriptions could be given in persons/year and costs per subscription in dollars/person/year. Total cost of all subscriptions would then be determined by subscriptions*subscription cost. To assign a time unit to the total cost of all subscriptions I multiply by the TIME STEP. That leads to subscriptions*subscription cost*TIME STEP.
However, if TIME STEP is not 1, actual cost of all subscriptions would be changed. Therefore, I again divide by the absolute value of the TIME STEP: subscriptions*subscription cost*TIME STEP/(1/32) (if TIME STEP = 1/32).
My question is whether there is a more elegant solution to this. In most cased, TIME STEP is probably not changed. So it shouldn’t be a problem having “1/32” as a fixed value in the equation. However, is there a way of getting the absolute value of the TIME STEP and leaving out its unit? With TIME STEP/TIME STEP time reference would be shortened directly.
I'm really looking forward to your responses!
Best wishes,
Marvin
Getting value of TIME STEP while leaving out its unit
Re: Getting value of TIME STEP while leaving out its unit
I'm not sure you have the units specified correctly.
Are you sure "costs per subscription" has the correct unit? I'd say it should be "dollar/person" (or dollar/subscription). Or maybe have a stock of "current subscribers" (people) and multiply that by the subscription cost per year?
Multiplying by time step to avoid unit errors is really not the correct thing to do.
I agree with Tony's assessment - subscriptions seems like a stock, with units of people (or person*years/person).
However, there are certainly legitimate uses for the kind of conversion you're requesting. I would normally just create a "unit year" variable with the appropriate units, and make it an unchangeable constant.
