I have a model that behaves differently when one uses a simple simulation setting a parameter value with the set button, or is on uses the synthesim modifying the parameter value using its slider.
I have included the model in vpmx format and two runs;
the first run named current has the parameter 'pression fixe' set to 0.15. And can be reproduced setting the parameter to 0.15 with an ordinary simulation.
the second run named sys_current has the same parameter set to 0.15 but with the slider. It can be reproduced using the synthesim sliding the parameter value to 0.15.
Both runs when compared have no differences in parameter values but have a different value for 'probabilité d'acceptation de la demande en simulation'
Rather strangely if before using the synthesim one sets the pression fixe to 0.15 and then one enters the synthesim, both runs have the same results, but as soon as one moves the slider, the results of the synthesim becomes wrong.
Any idea?
Best regards.
PS: it is impossible to attach a file with the extension vpmx, i have then attached the ,mdl version and the two files.
problem with a small model
- sys_current.vdfx
- (27 KiB) Downloaded 99 times
- current.vdfx
- (27 KiB) Downloaded 97 times
- test.mdl
- (4.3 KiB) Downloaded 96 times
Re: problem with a small model
Joined three workarounds that seem to work correctly. i prefer the test3 or the test4 that are safer. the test 2 works but i am not sure in all circumstances.
Best
Best
