I am running MCMC to get best estimated constant values.
The best constant values after MCMC will be available as *.log files.
After obtaining the best constant values through MCMC
our models are still with their default values.
Is there a way to use the best constant values automatically as
default values before running simulation(s)?
use optimised parameters as starting values
Re: use optimised parameters as starting values
It should generate a .out file, that can be used as a changes file in sim control to read the optimized values.
See
https://www.vensim.com/documentation/cin_files.html
and
https://vensim.com/conference/#vensim-c ... 211-part-1
and
