sensitivity analysis
neda65
Post by neda65 »
hello everyone
I would like test sensitivity analysis for my model. I used simulation control window, but in the parameter section, i can only select constant parameters, and when I use the auxiliary and driving variables, it gives an error.
RROR: NDVI not found or wrong type must be constant.
NDVI=RANDOM_UNIFORM(0.01,2).
Line 2 of file sensitivitymodel.vsc.
ERROR: No sensitivity inputs marked in sensitivity file.
why??
Re: sensitivity analysis
Your profile has you listed as a PLE user, PLE does not have sensitivity analysis. Can you update your profile please?
You'll need to upload your model/files for us to be able to tell you what is wrong.
This is by design - you can't specify complex behavior for an auxiliary via a simple distribution.
There are many possible ways to vary an auxiliary, but if you tell us what you're trying to do we might be able to suggest one.
neda65
Post by neda65 »
Thanks for your reply.I attached my model. In this model Phytomass is a level variable, temperature and precipitation are driving variables, NDVI is an auxiliary, Stock and Consumption rate are constant variables. I would like to do a sensitivity analysis for Phytomass, Which variables have the most effect on phytomass.
My question: Is the sensitivity analysis only for constant variables or can it be done for other types of variables (i.e., auxiliary, driving )?
neda65
Post by neda65 »
Thanks for your reply. I update my profile. I attaches the model image.
neda65 wrote: Sun Feb 12, 2023 4:08 pm Thanks for your reply. I update my profile. I attaches the model image.
Please complete the serial number part of your profile.
Looks like you could either vary temperature and precipitation directly, or add a third term to NDVI representing variation around the f(temp,precip) and add the variation to the voc.
