Units do not match
lagraberry
Units do not match
Post by lagraberry »
Right hand and left hand unit of replicator dynamics equation do not match
replicator dynamic equation:dy/dt=y(1-y)(URC-URN)
The left hand:percent/Month
The right hand:CNY
Although Units equivalents [percent/Month,CNY] were set, this problem still exist.
Thank you for your answer :D
Re: Units do not match
Can you upload the model?
And what units are "CNY"? I've never heard of this as a unit/dimension.
lagraberry
Thank you for your reply.
I have been uploaded the model.
The unit "CNY" is the chinese currency unit.
SD model of tripartite evolutionary game under F-scheme.mdl
(14.36 KiB) Downloaded 1523 times
First of all, remove the units equivalence "percent/Month,CNY". CNY is currency, percent/month is definitely not. You use units equiveillances for things like "month,months" or "person,persons,people,human".
Looking at your model, start by putting in units for all of the parameters. These units should match reality, if something is an interest rate, it should be something like percent/year or percent/month etc.
I've got no idea what all the parameters refer to in this model so cannot really offer any more advice.
lagraberry
Thank you for your help.
I want to set the rate(variable)'s unit in eqution: dx/dt=x'(t)=a×x(t),a is const.
But, units do not match(left and right hand).
x(t) represent the probability of selecting one strategy, i set the unit: Dmnl,
but the unit of [dx/dt] must be the 1/Month(or other time type), so i can not match the units between the 2 sides.
Could I explain my question clearly?
Wish for your help.
Thx...
Units should always be very straightforward. Always enter what the parameter would be measured in in the real world.
Can you upload the model? It's difficult to offer advice with so little to work on.
I'd suggest that the probability is correct, that should be dimensionless. Cannot really offer any more advice without seeing the model.
lagraberry
I have been uploading my model.
I am waiting for your help.
Thx
simplify sys1.mdl
(4.02 KiB) Downloaded 1834 times
lagraberry
Administrator wrote: Tue Apr 18, 2023 10:32 am Units should always be very straightforward. Always enter what the parameter would be measured in in the real world.
The unitrate was set as Tolerances for Arithmetic Sequences, i.e. dx/dt=Δx, the unit of left is 1/time, but the unit of right is 1.
How can I match the units?
Thx
Fist thing, δx should have units of DMNL/month as it's a rate of change.
I cannot really offer any more assistance as the model is not documented, I've got no idea what things like "L1" are (or if the units for it are even correct).
lagraberry
Administrator wrote: Thu Apr 20, 2023 1:41 pm Fist thing, δx should have units of DMNL/month as it's a rate of change.
When I simulate, there will be a variable out of range fault.
How can I debug?
Thx
variable D-1.jpg (136.27 KiB) Viewed 35577 times
fomula.docx
(374.95 KiB) Downloaded 1505 times
simplify sys1.mdl
(10.36 KiB) Downloaded 1663 times
lagraberry
lagraberry wrote: Mon Apr 24, 2023 6:39 am
How can I debug?
Thx
This is the next variable definition.
variable D-2.jpg (103.73 KiB) Viewed 35576 times
BarryDawson
Post by BarryDawson »
By multiplying the right-hand side of the equation by this conversion factor, you can ensure that the units match. The modified equation would then be:
dy/dt = y(1-y) * conversion_factor * (URC - URN)
