Units do not match
Posted: Mon Apr 03, 2023 1:30 pm
by lagraberry
Right hand and left hand unit of replicator dynamics equation do not match
replicator dynamic equation:dy/dt=y(1-y)(URC-URN)
The left hand:percent/Month
The right hand:CNY
Although Units equivalents [percent/Month,CNY] were set, this problem still exist.
Thank you for your answer
Re: Units do not match
Posted: Mon Apr 03, 2023 3:59 pm
Can you upload the model?
And what units are "CNY"? I've never heard of this as a unit/dimension.
Posted: Tue Apr 04, 2023 4:08 am
by lagraberry
Thank you for your reply.
I have been uploaded the model.
The unit "CNY" is the chinese currency unit.
Posted: Fri Apr 07, 2023 7:41 am
First of all, remove the units equivalence "percent/Month,CNY". CNY is currency, percent/month is definitely not. You use units equiveillances for things like "month,months" or "person,persons,people,human".
Looking at your model, start by putting in units for all of the parameters. These units should match reality, if something is an interest rate, it should be something like percent/year or percent/month etc.
I've got no idea what all the parameters refer to in this model so cannot really offer any more advice.
Posted: Tue Apr 18, 2023 9:04 am
by lagraberry
Thank you for your help.
I want to set the rate(variable)'s unit in eqution: dx/dt=x'(t)=a×x(t),a is const.
But, units do not match(left and right hand).
x(t) represent the probability of selecting one strategy, i set the unit: Dmnl,
but the unit of [dx/dt] must be the 1/Month(or other time type), so i can not match the units between the 2 sides.
Could I explain my question clearly?
Wish for your help.
Thx...
Posted: Tue Apr 18, 2023 10:32 am
Units should always be very straightforward. Always enter what the parameter would be measured in in the real world.
Can you upload the model? It's difficult to offer advice with so little to work on.
I'd suggest that the probability is correct, that should be dimensionless. Cannot really offer any more advice without seeing the model.
Posted: Thu Apr 20, 2023 5:40 am
by lagraberry
I have been uploading my model.
I am waiting for your help.
Thx
Posted: Thu Apr 20, 2023 5:46 am
by lagraberry
Administrator wrote: ↑Tue Apr 18, 2023 10:32 am
The unitrate was set as Tolerances for Arithmetic Sequences, i.e. dx/dt=Δx, the unit of left is 1/time, but the unit of right is 1.
How can I match the units?
Thx
Posted: Thu Apr 20, 2023 1:41 pm
Fist thing, δx should have units of DMNL/month as it's a rate of change.
I cannot really offer any more assistance as the model is not documented, I've got no idea what things like "L1" are (or if the units for it are even correct).
Posted: Mon Apr 24, 2023 6:39 am
by lagraberry
Administrator wrote: ↑Thu Apr 20, 2023 1:41 pm
When I simulate, there will be a variable out of range fault.
How can I debug?
Thx
by lagraberry
lagraberry wrote: ↑Mon Apr 24, 2023 6:39 am
How can I debug?
Thx
This is the next variable definition.
Posted: Sat May 20, 2023 6:39 am
by BarryDawson
By multiplying the right-hand side of the equation by this conversion factor, you can ensure that the units match. The modified equation would then be:
dy/dt = y(1-y) * conversion_factor * (URC - URN)
