Dear colleagues.
Is there any tool in Vensim that presents the equations we develop in the model for each variable but under the formal language of mathematical analysis typical of differential calculus?
That is, not in the form of the programming language that is accessible in the "document" or "document all" button/option.
Thank you so much.
Query about analytical equations
Re: Query about analytical equations
Can you give an example of what you want? It may be possible with existing tools, but I don't know what format you need.
For example:
Modeled and documented equations in vensim form:
Stock=input-output
Flow=ABS(variable 2+variable 3 )
I'm looking for this kind of language:
Stock=∫(Input-ouput)dt+initial stock
Flow= |variable 2+ variable 3 |
Thank you very much
Stock=input-output
Thank you very much
Not at present, but the Doc tool is slated for an update, so I'll add this to the list.
