I can't set Emscripten path in Vensim
Posted: Thu Apr 27, 2023 7:29 am
Hi everyone. I want to use Emscripten with Vensim, because I want to publish to the web. According to the official guide, if you click Tools->Options you end up in a modal containing the Startup tab in which you can set the Emscripten path. But I end up in this modal which doesn't give the possibility to set it.
![Image]()
