I am running a multivariate sensitivity analysis with 20+ variables using PLE+9.4.2. I am using a Uniform random distro. How do I set the increments for each variable (Example Min =1, Max = 10, Increments =.1)?
Thanks for your help!
Incrementing Sensitivity Analysis Variables
- Vensim version: PLE+
Re: Incrementing Sensitivity Analysis Variables
You probably want to use the VECTOR distribution instead, this allows a min, max and increment.
https://www.vensim.com/documentation/se ... ensitivity
https://www.vensim.com/documentation/usr15.html
