Hi there,
I please need some troubleshooting assistance.
I installed Vensim PLE on 07/06/23. I used it throughout June and July with no problem.
I tried to open it yesterday 17/08/23 and received an error of "The limited time copy has expired"
I ran it as administrator and still get the same error.
I restarted my laptop too.
I attach the error image.
I am running Windows 11, using my work laptop.
If someone could please assist, I need to build a causal loop diagram for my assignment.
Vensim PLE, limited time copy has expired
- Vensim version: PLE
- Vensim error.jpeg (54.81 KiB) Viewed 335 times
Re: Vensim PLE, limited time copy has expired
When you originally installed Vensim, you were given the option of evaluation, licenced or academic. You must have selected evaluation, you need to re-install, this time select the option for academic use.
Thank you so much!!!
