Suppress simulation information window
Although the "Suppress simulation information window" is enabled, the info window pops up every time I use an output file to read constant changes. Is there a way to avoid this?
- Screenshot 2023-10-24 at 10.28.59.jpg (43.18 KiB) Viewed 4014 times
- Screenshot 2023-10-24 at 10.28.44.jpg (182.47 KiB) Viewed 4014 times
Re: Suppress simulation information window
Can someone please clarify if this is a bug or a feature?
Thank you!
Thank you!
I think it's a bug - there are a few instances of warnings that ignore the settings check.
Thanks for the clarification, Tom.
