In prior versions of Vensim, there have been the keyboard shortcuts to select sketch tools or analysis tools.
Sketch tools are 1,2,3,4,...q,w,e,...
and analysis tools were control-1,2,3,4,...,q,w,e,...
I can select sketch tools with shortcuts still (though less consistently than before) but I can't select analysis tools. Is this a bug when the toolbars got written?
BUG? Control-<number> not select analysis tool
Re: BUG? Control-<number> not select analysis tool
Sounds like a bug, because it's still working on Win10 (assuming you're using a Mac).
Yes, I'm on macOS.
Kinda related, but did custom Sketch Toolbars go away in the New UI? I only see Analysis Toolset in the Tools menu.
Any confirmation that you see this issue on macOS?
I'll try and add it in. Programming for MacOS is proving to be quite a challenge at the moment.
