Arrow Options
johnjohnson4
Vensim version: PLE+
Arrow Options
Post by johnjohnson4 »
I noticed that when changing the defaults in Arrow Options, I have to make the change twice before it saves. For example, if I change the default size for the polarity, it does not save the first time. I have to make the change again then then it will save. Is this a known problem or am I doing something wrong?
Re: Arrow Options
Can you provide more detail please? I've tried changing the defaults (Tools->Options->Sketch, arrow options), things worked fine for me. Running Windows version of Vensim.
johnjohnson4
Re: Arrow Options
Seems to only happen when changing arrows from default fonts to custom fonts.
1. Right-click on an arrow handle
2. Un-check the Polarity default button
3. Click on the font "button" on the right side of the "default button."
4. Change the font size, click OK
The font does not change. If I repeat steps 1, 3 and 4, then the font changes.
