I'm trying to publish the model into web files, and I'm on Windows 11 version 22H2, Python 3.12.0, and Vensim 10.1.2, but the HTML file doesn't show the custom graph. How would I fix that?
FYI, I've attached the model and the web files. Also, I just installed Emscripten SDK and WASM complier, and I'm pointing to the right folders in Vensim settings.
Publish to web not showing graphs
- Model.zip
- (214.88 KiB) Downloaded 95 times
Re: Publish to web not showing graphs
What is the web address where you have uploaded this to?
As I mentioned in the original post, the web files, including the HTML index file, are in the attachment. Also, I'm attaching a screenshot of what I see here.
- Screenshot 2023-11-17 at 14.15.27.jpg (94.78 KiB) Viewed 4963 times
You need to upload it to a website for it to work. Running locally in a browser will not work.
You can set up a server on your local machine. I'll send instructions when I'm back in front of a computer.
https://www.vensim.com/documentation/4_ ... ng-on.html
C:\Users\Public\Vensim\COMP\wasm
there are two files (StartPythonWebserver.bat and WebServer.py). These can be copied to your "web" folder, and if you run "StartPythonWebserver.bat", it should start the Python script and set your machine up as a server. Then you can view the files in a browser without uploading to a website.
If you browse toYou now need to copy all of these to a web server. There is plenty of information on the internet on how to do this,
https://developer.mozilla.org/en-US/doc ... web_server
Thank you very much, Tony. It worked. I see the machine is set up as server. Thanks again!
- Screenshot 2023-11-20 at 13.46.50.jpg (136.76 KiB) Viewed 4898 times
For security reasons, you have to run via a server.
