Output File
Output File
I have 20 different stocks that I have created and is there a way to combine their last values in another excel file?
Re: Output File
You can add them all together in a new variable and look at the value of that at FINAL TIME.
Re: Output File
Or perhaps what you're looking for is an export of the dataset to Excel? Use Model>Export Dataset.
Re: Output File
No, you cannot export using PLE.
You can create a table though and copy/paste the values into Excel.
Re: Output File
I can do it that way only when I paste it into Excel. (period) and , (comma) errors are bothering me.
Re: Output File
Also, something I'm curious about is; Can I show the data for 20 months as a single data instead of a time period and use it as a constant in the next time series formula?Administrator wrote: ↑Fri Dec 01, 2023 8:37 amNo, you cannot export using PLE.
