I tried to write a very simple text with paragraphs.
Being not able to copy the text on the textonly venapp control, i was obliged to suppress the paragraphs.
Joined a word file with the text with the paragraphs and without paragraphs.
After that to obtain a text with pargrpahs i have found two ways to do it.
The first adding blank spaces accordingly to the text and the second by adding a textonly control for each line which seems more practical.
Is there a more simple way to do that?
Joined the word file projet and the two .vcd files
Best regards.
writing text withe the Venapps tool
- essai8.vcd
- (1 KiB) Downloaded 164 times
- essai7.vcd
- (1.14 KiB) Downloaded 159 times
- Projet.docx
- (10.39 KiB) Downloaded 165 times
Re: writing text withe the Venapps tool
Sorry, I do not know what you are asking for help with.
Venapps are not very flexible, all you can really do is add textonly for each line of the paragraph.
I do not agree with you.
You write:
'all you can really do is adding textonly for each line of the paragraph.'
I do not know if you have read the two solutions that I have exposed: one is with a textonly for each line as you propose but the other one is with only one textonly for the whole text with 8 lines.
With the new GUI, with the text input output objects, you can easily write a text with the paragraphs as you wish them to be formatted.
I just wanted to know if there is with the Venapps a same possibility.
You write:
