Feature request: make loop polarity direction indicator vector graphics
Posted: Thu Feb 01, 2024 12:18 pm
by kleemax
The loop polarity direction indicator image is pixel graphics. When the rest of the model can be exported as vector graphic, the pixel graphic looks strange. Furthermore, If I am not mistaken, earlier Vensim Versions did have vector versions of the loop polarity direction indicator. It would be really cool if you could change this to vector graphics.
Re: Feature request: make loop polarity direction indicator vector graphics
Posted: Thu Feb 01, 2024 12:24 pm
What version of Vensim are you using? And new or old GUI?
Can you upload a sample model, as they should be vector graphics (they have been for some time).
Posted: Fri Mar 08, 2024 2:26 pm
by kleemax
I have attached a model as well as a screenshot of what I see on the screen.
I am using Vensim 10.1.3
Posted: Fri Mar 08, 2024 2:31 pm
by kleemax
Problem solved: there is another way to set the loop polarity indicator in the new gui it's under "shape". I had not expected to find it there and had hence only found the pixelish alternative under images...
I have found this by going back to old gui, seeing nothing, then setting them the way I was used to and saw the vector graphics ones and then switched to new gui to find where the correct setting is.
Posted: Fri Mar 08, 2024 3:45 pm
The old GUI is no longer supported. The new GUI already does quite a lot more than the old (such as vector graphics).
You can also find a SVG of the image you want, save it to the model folder and use that as an image.
