For the system dynamics model that I am working on, I am using the Vensim Professional license. However, I would like to start with the automatisation of runs, parameter tuning etc. Is it true that this is not possible without the Vensim DSS license?
Futhermore, in the Vensim store I saw that there are multiple trainings. Which training would teach me most about using scripts to run Vensim and more advanced possibilities? Is this training purely online, at your own pace? And when was this training released? I'm not sure about following the training just yet, as I feel the interface has changed quite a bit and doesn't always match up with the tutorials on the website.
Thanks in advance!
Kind regards,
Britt
Vensim training
Re: Vensim training
Can you explain what you mean by this? If you mean scripting (command scripts), these are only in DSS.
Can you email us regarding this, I'll put you in touch with the tutor.BrittZ wrote: ↑Thu Feb 01, 2024 2:52 pm Futhermore, in the Vensim store I saw that there are multiple trainings. Which training would teach me most about using scripts to run Vensim and more advanced possibilities? Is this training purely online, at your own pace? And when was this training released? I'm not sure about following the training just yet, as I feel the interface has changed quite a bit and doesn't always match up with the tutorials on the website.
Re: Vensim training
Thanks for your response.Administrator wrote: ↑Thu Feb 01, 2024 3:07 pmCan you explain what you mean by this? If you mean scripting (command scripts), these are only in DSS.
For the model I am running multiple scenarios with different parameter values. I am doing this manually which takes up a lot of time and is sensitive to errors. I thought the use of scripts was only available for the Pro version of Vensim, but looking at your answer I think it is also possible in DSS?
I will send you an email - what email address should I send it to?
Thank you.
Re: Vensim training
It's only available in DSS.BrittZ wrote: ↑Mon Feb 05, 2024 7:11 am For the model I am running multiple scenarios with different parameter values. I am doing this manually which takes up a lot of time and is sensitive to errors. I thought the use of scripts was only available for the Pro version of Vensim, but looking at your answer I think it is also possible in DSS?
