I find that I cannot have the name run as 'Ratio of scrapped car = 0' and 'Ratio of scrapped car = 0.5' at the same time (I want to do extreme condition test). Specifically, the run including '0.5' will be automatically converted to '0' and the actual '0' run is replaced.
How to resolve the issue? Thank you.
Issue with the name run
Re: Issue with the name run
I'll raise this as a problem.
You could try "Ratio of scrapped car = 0.5.vdfx".
Traditionally in Vensim, you don't need to specify the filename extension when running a simulation. For example, you can enter "run 01" and Vensim will create "run 01.vdfx". Vensim searches for the "." and replaces it with ".vdfx".
