two imodels with no significant differences behaving differently
Posted: Mon Apr 01, 2024 2:15 pm
Joined two very simplistic models that are similar but generate different results.
the problem comes from the lookup table.
if you campare the lookups in both models they are the same in the equation tool, and in their graph.
Bu it you look at the values of the lookups in the table tool they are not the same in the runs from both models!
To summarize , the models are the same as models but not the same when you run them!
Best regards.
Best regards.
