The new DSS version has now all the controls available.
I join two models that have both a button control. The first model essai.mdl has a button whose name is ‘go to next view’ and with a control that effectively goes to the next view. If one publishes the model into a .vpmx model and one opens the .vpmx model with the model reader, the button works correctly. The second model essai_2.mdl has a button whose name is ‘go to the view view 2’ with a control that goes to the view 2. If one opens the model essai_2.vpmx with the model reader the button does not work!
Question: if one opens a model built with Vensim DSS and published into a .vmpx model with the model reader, is that model behaving with the model reader the same way that it behaves with the Vensim DSS?
Best regards;
control button not working the same way in DSS and reader
- essai_2.mdl
- (1.63 KiB) Downloaded 215 times
- essai.mdl
- (1.62 KiB) Downloaded 227 times
Re: control button not working the same way in DSS and reader
The model seems to work the same way than the DSS. Going to the view view 2 seems to be a bug.
it would be useful to have somewhere an explanation of the 9 added controls plus some exemples like the Venapps examples.
Thanks, I'll get it fixed ASAP.
